Started to trim the rear canopy front and rear edges to fit flush with the sliding part. On the turtle deck I cut out a band of about 2cm for the rear canopy- the foam was shaped the fit the angle of the canopy trailing edge. There is some adjustments to make in order to look nice and flush when it comes to the transition from the front to the rear canopy. Ther rear bow was all of a sudden ( probably due to the weight of the front canopy which ended up a little lower after glueing) to high, so I had to shorten it 2-3 mm. Now it's still a little too much to the right. Will correct this tomorrow.
